Overheating and losing power
2006 LINCOLN AVIATOR
200,000 MILES • V8 • AWD • AUTOMATIC
BEVERLY OFERRALL
Yesterday I had no heat in the car in the morning. Continue to drive it. Later it overheated and lost power. The reservoir was still filled with fluid. I was able to get home by letting it cool down and driving slow, it would overheat and I would pull off the road, shut it down, and let it cool down again, and kept repeating this.
May 23, 2017 at 4:58 AM
HMAC300
  • 48,601 POSTS
make sure the cooling system is full not just reservoir if it overheats it will lose power. pressure check cooling system for a head gasket leak. also, check for a stuck closed thermostat. it can be a few things but you need to start first for leaks.
May 23, 2017 at 5:42 AM
