Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Truck
Engine
Symptoms
Overheat
Overheating
2000 FORD TRUCK
75,000 MILES • V12 • 2WD
RANDY WHITE2
MEMBER
1 POST
FOLLOW
Clutch fan won't engage until engine temperature is red line. Clutch was replaced as old one did same thing.
May 29, 2019 at 2:03 PM
CERTIFIED EXPERT
When you replaced the fan clutch did you use OEM? Also I have seen a blown head gasket cause this problem lets run this test to confirm:
May 30, 2019 at 2:10 PM
