Engine gets hot and fans do not turn on. Lower radiator hose hot, upper not. Both heater hoses get hot so I assume water pump is OK. Removed thermostat and all hoses hot. Fan didn't come on. Tested fan by supplying current and ground directly to resistor. Fan fuse and relays test ok. Only powered relays directly and contact clicked. Didn't check to see if current was being sent out other terminals. I unplugged the temp sensor on T-stat housing no change. I was going to jump the connector but didn't have time. Is it possible the resistor is still bad even though the fan came on when I powered it? Is it possible an air pocket is causing the overheating? What's my next course of action?
Sep 24, 2024 at 6:06 PM
