Okay, good. The wrong coolant mixed with DexCool can cause a major issue. So, if I understand correctly, it doesn't overheat at highway speeds. Instead, it happens when you stop after driving 15 minutes or so, and the cooling fans are working.
Don't laugh, but make sure when it gets hot that neither the upper or lower radiator hoses have pinched shut restricting coolant flow.
If that is good, then I have another suspect. You indicated in the first post that when you add coolant, air keeps coming out even though you had it full. Did you use the bleeder to eliminate trapped air in the system? If you did, then does the radiator appear corroded inside? Does the heater work?
Let me know those. Also, I need you to check for a possible head gasket issue. Have you ever noticed any white smoke from the exhaust? Does the coolant ever bubble before the engine overheats?
Sorry for so many questions. Do me a favor. Take a look through these links and let me know if anything mirrors what you experience and if you are able to perform the tests in the second link.
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
One other link I feel you may find helpful and of interest.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
The idea that it only has 60K miles leads me to think the radiator and cooling system components should be fine. That is why I'm asking you to check for a possible head gasket issue.
May 26, 2024 at 7:54 PM
