Overheating
2002 SATURN SL1
200,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
KAYLAD94
Car keeps overheating, does not have any visual leaks. Temperature has rises within thirty minutes or less. I am running water in it for now but it keeps boiling out as soon as it heats up. It did have steam from exhaust once. But it is also cold. We took the thermostat off nothing changed. We did get a code for the ECT sensor being bad. i am wondering how likely could that be the issue to it overheating continuously?
Jan 29, 2018 at 2:52 PM
The smoke out the exhaust is the key. it sounds like you have a damaged head gasket from the overheating. it is burning the coolant and the coolant becomes superheated from the failed head gasket.
you need someone to do a leak down test on each cylinder to determine the cylinder where it is leaking.
Jan 30, 2018 at 9:25 AM
KAYLAD94
Oddly enough i changed the radiator cap and it has not overheated so far. I was not sold on it being the head gasket only because the steam from the exhaust was not thick at all and with the weather being cold it is already going to be having condensation built up correct?
Jan 30, 2018 at 10:12 AM
no, the fact it has continually overheated leads me that direction. You need to have it verified that the head gasket is not damaged.
Jan 30, 2018 at 10:25 AM
KAYLAD94
So even though its no longer running hot i still should not assume that the head gasket is not bad? What are for sure signs of it being the head gasket so i can look for them? Because it is running perfect now.
Jan 30, 2018 at 3:44 PM
bubbling in the cooling system, heat working and not working at times, temperature gauge moving up and down and smoke, white smoke, out the tail pipe are indicators.
also, do not run with just water and no thermostat. install a new thermostat and a 50/50 mix of coolant.
Jan 30, 2018 at 3:46 PM
