Overheating
2004 HOLDEN RODEO
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
JULES4
overheats and seems to have cooling system build up with pressure.
Apr 25, 2022 at 2:38 AM
BORIS K
  • 836 POSTS
Engine overheating and increased pressure in the cooling system usually point towards leaking cylinder head gaskets
I suggest doing a chemical block test.
How to.
https://youtu.be/riF5hdhz0wM
Also see images below
If the liquid of the block tester changes color this will indicate the presence of carbon monoxide in the coolant. This will then point towards leaking cylinder head gaskets or a possible cracked cylinder head. The cylinder heads will need removing and a suitable engineering shop should then check these for possible warped surfaces and do a pressure test to check if any cracks can be found.
How to check a cylinder head.
https://youtu.be/r9ktZAPjOKc
How the cooling system works.
https://www.2carpros.com/articles/engine-cooling-system
Once the engine has been repaired, if required, you should then determine what caused the engine to overheat. Leaks, faulty water pump or thermostat, possible blocked radiator?
Hope this helps.
Cheers, Boris
Apr 25, 2022 at 5:00 AM
