Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
Relay
Engine
Symptoms
Overheat
Overheating
2005 SATURN RELAY
42,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
KATHERINE DENISE LEHMKUHL-LEAVITT
MEMBER
FOLLOW
The coolant isn't returning back into the motor from the overflow reservoir.
Dec 19, 2018 at 8:44 PM
CERTIFIED EXPERT
Good morning,
Did you check the thermostat? that is responsible along with the water pump for circulation?
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
What work has been done since I see your a mechanic?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Dec 20, 2018 at 3:49 AM
MEMBER
Changed thermostat, radiator and coolant temperature sensor.
Dec 20, 2018 at 3:50 PM
CERTIFIED EXPERT
Got it.
The next step is to do a leak down test on the cylinders to check and see if there is a leaking head gasket.
that is where you insert shop air into each cylinder one at a time and watch for movement of the coolant in the radiator.
Dec 20, 2018 at 9:51 PM
