Car just started overheating. I put coolant in the radiator to correct level. Drive for an hour and it it boils and sprays out of overflow reservoir. I changed out the radiator cap and put put a new thermostat in (a fail safe one). It does not over heat as much, but still does. maybe two to three days now I have to put more coolant.
I checked the oil and no water is in it at all.
The water pump does not make any sounds to indicate it is bad.
The heater works fine with no smell of antifreeze.
It does not leak anywhere except when it spays out of the overflow reservoir.
Any suggestions on what could be causing the overheating?
Thank you, Keith
Thank you, Keith
Jan 31, 2017 at 9:26 AM
