You are very welcome. Hang in there. We can get this figured out. You said there was smoke behind the engine. Does it have a sweet smell to it, or does it smell like it could be oil burning?
I attached a pic below showing the heater hoses. They are at the rear of the engine. They travel from the engine to the firewall. See the pic. Check to see if there is any evidence of a leak from one of the hoses.
Also, if you have no heat, there is a good chance the coolant is low or there is air in the system. At the top of the thermostat housing is a bleeder valve. With the engine cold and not running, loosen it to see if coolant starts to leak from it. If it doesn't, it is likely low or has air in the system.
With that bleeder open, add coolant until it starts to come out of the bleeder. (See pic 2 below)
Let me know what you find.
See pics below.
Aug 24, 2024 at 7:24 PM
