Overheating
2000 DAEWOO LANOS
80,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DIPPIES
Fans come on at boiling point if i unplug fan switch on cylinder head fans come on heat gauge stands on below normal.
Nov 7, 2019 at 2:38 AM
Good morning,
By removing the plug, it sends a hot signal to the ECM and the ECM commands the fans to come on.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Sounds like the switch that you disconnected may be the issue or the thermostat may be the issue.
Nov 7, 2019 at 2:50 AM
DIPPIES
Why shows heat gauge below normal but water temperature is at boiling point?
Nov 8, 2019 at 3:46 PM
Because of where the sender unit is located.
Did you replace the thermostat?
Nov 9, 2019 at 12:44 PM
DIPPIES
On Daewo Lanos how do you bleed air out of cooling system?
Nov 11, 2019 at 12:20 PM
