Overheating
2012 KIA RIO
12,200,000 MILES • 1.6L • 2WD • AUTOMATIC
CYCY
The gasket has been worked on before after an accident.
Nov 5, 2018 at 8:17 AM
Which gasket are you referring to? Also, here is a link that discusses the cooling system, how to check for leaks (if you have one) and how to replace a thermostat:
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/radiator-pressure-test
____________________________-
If the gasket you referred to is the head gasket and you suspect there is a problem with it, here is a link that shows how to check for a head gasket leak:
Let me know if there is something other that you are aware of. Also, if you have other questions or need additional help or information, feel free to ask.
Nov 5, 2018 at 8:09 PM
CYCY
Thank you let me check in further.
Nov 6, 2018 at 6:32 AM
No problem. Let me know if I can help.
Nov 6, 2018 at 5:08 PM
