My girlfriends truck is overheating and I can’t find the root of the problem. I have changed the thermostat and flushed the radiator and put all new coolant in. Her father had a brand new water pump put on it and “he says” they flushed the heater core before I could get my hands on it. The temperature fluctuates up and down very quickly. But there is no smoke and the oil isn’t milky and no fouled plugs so I have ruled out the head gasket. Faulty thermostat from AutoZone or air pockets stuck in the cooling system were the last thing I could think of. But I purchased the best/most costly thermostat from AutoZone and used proper coolant and it shows no evidence of a leak because I don’t see coolant on my driveway or any area I park for extended period of time and my coolant levels aren’t dropping enough to have a leak. Could a whole engine flush help? Use synthetic when filling the oil back up? The truck is very high mileage tho, only 129,000. Any help or direction would be much appreciated, thank you.
May 1, 2020 at 8:43 PM
