it has been overheating since last year. At first I send the radiator to be repaired and they said the problem is that the engine is releasing too much pressure which has cause the radiator to expand. when I put it again on the car after being repaired it started to leak again within some hours. Then i decide to put a new water pump, but still the problem still remained the same. it did get better when i removed the thermostat, but still overheating. Now I took the head for skimming put a new gasket set but the car is refusing to start only cranking. So we started it using quick start but there is desiel knock sound. So I am desperate and confused, we tried to blow the injectors but it did not work and before it was starting without a problem. Thank Steven
Sep 29, 2016 at 1:49 AM
