Overheating
2004 BUICK RENDEZVOUS
100,000 MILES • 3.4L • 4 CYL • 2WD • MANUAL
My vehicle overheats while sitting, had new engine.. after that replaced bad gaskets, new radiator, new sensor, new thermostat, new water pump, and bled air from coolant system, but still overheats.
Jun 3, 2021 at 4:09 PM
Good evening,
Do the cooling fans work? Make sure they come on when the engine gets hot.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
I attached a diagram for you of the system. Check for voltage to the fans when running and the engine is hot. Test the fuses in the diagram for power on both sides. When there is overheating at idle only, it is usually from lack of air through the radiator.
Jun 3, 2021 at 6:14 PM
