Overheating
1997 TOYOTA RAV4
130,000 MILES • 4 CYL • AUTOMATIC
RAYRAMROD62
I changed (with new parts from NAPA ) the radiator, CO2 oxygen sensor, thermostat with casing, the water pump kit with timing belt. I even place a Spit Fire spark plug to burn the oil in cylinder three. The car still overheats. What else can I do to resolve this issue?
May 10, 2018 at 7:56 AM
Good morning.
I sounds like you have covered most of the reasons but from the overheating, it may have damaged the head gasket leaking superheated combustion gases in the coolant.
You can get a chemical kit and check the head gasket from a parts store. That will tell if you have any gases in the coolant indicating a failed head gasket.
https://www.2carpros.com/articles/engine-cooling-system
May 10, 2018 at 8:55 AM
