Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lincoln
LS
Engine
Symptoms
Overheat
Overheating
2002 LINCOLN LS
156,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
STACYLYNN7
MEMBER
FOLLOW
My vehicle listed above overheating had codes read said thermostat. changed still overheats.No leaks.thinking it is the water pump.
Feb 2, 2020 at 6:10 PM
CERTIFIED EXPERT
Good evening,
What were the codes? Codes do not identify bad parts, just failed systems.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
This could be a water pump but needs to be tested to see if there is circulation.
Did you check the cooling fan motor to see if it is working?
Feb 2, 2020 at 6:45 PM
