Overheating
2001 TOYOTA AVALON
160,000 MILES • 1.5L • 3 CYL • FWD • AUTOMATIC
GABE24
  • 5 POSTS
So I bought and replace a new radiator yesterday and filled it with water let it run for about ten fifteen minutes. I drove it home, today i started it up then filled the radiator with coolant and let it run until it got warm inside bout ten minutes. Drove it around a little and parked it. Maybe an hour later I go to take it for a drive and it starts over heating I think when I had it on in park. But then the heater stopped working and when I began to drive the gage was going up then down then just continued to raise so I had to drive a little and stop til I got home which was only a few miles. But it was steaming real bad only coming from the little hose that goes into the little coolant tank the overflow I think it's called.
Feb 4, 2016 at 11:38 AM
HMAC300
  • 48,601 POSTS
check thermostat if it heats up really fast also check radiator cap if it continues have it pressure checked for an internal leak like a head gasket.
Feb 4, 2016 at 12:05 PM
GABE24
  • 5 POSTS
Ok thank you I will try replacing the thermostat
Feb 4, 2016 at 1:03 PM
GABE24
  • 5 POSTS
I replaced the thermostat and it still seems to blow steam out of the over flow tank breathing tube. My fans work and keeps my radiator cool
Feb 7, 2016 at 9:47 AM
HMAC300
  • 48,601 POSTS
so like I said in first reply sounds like a head gasket problem.
Feb 7, 2016 at 11:29 AM
GABE24
  • 5 POSTS
But there is no coolant or water in the oil
Feb 7, 2016 at 3:04 PM
GABE24
  • 5 POSTS
What about the cap or the water pump?
HMAC300
  • 48,601 POSTS
it doesn't matter if ther eis no coolant in oil or oil in water, it can still be a head gasket get it pressure checked. the cap should be checked as well but that won't cause you to overheat.
Feb 7, 2016 at 3:17 PM
