It has never overheated before. Last week, while in stop and go traffic on the freeway, my water pump broke. I got off at the next off ramp, which took about ten
minutes. It did not get into the red zone and did not over boil. I had a mechanic
replace the pump and thermostat. On my way home it started to overheat
and get close to the red zone. By turning my heater on full blast I was able to
keep it in the normal zone. On my way back to the mechanic the next day, it
ran hot again. I kept the heater on full blast so that it stayed in the normal
zone. He changed by radiator but I still had the same problem. He suggested
changing the radiator fan, which I will do but I do not think it will solve the
problem because it seems to be kicking in when it is supposed to. There is no
oil in the coolant reservoir tank or milkiness in the oil but I am concerned it is
the head gasket. Any thoughts? Am I missing something obvious?
Aug 9, 2018 at 2:49 PM
