Overheating
2002 GMC ENVOY
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARTIN SIREKIS
Overheating soon after starting to drive it. Replaced thermostat and there are no leaks throughout. There is oil in the spark plugs and I cleaned it out and replaced them. Also had a radiator flush. There is no build up on either the oil cap or the radiator cap. Still overheating.
Apr 3, 2017 at 4:43 PM
Hey Martin,
Even though there is no build up on the cap you could still have a blown head gasket, can you do a chemical check please?
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 6, 2017 at 4:29 PM
PTEVENDALE
Engine Cooling problem
2002 GMC Envoy 6 cyl Four Wheel Drive Automatic 188000 miles
My car keeps over heating every couple of hours of driving. Each time the radiator is only a third of a gallon of coolant low. There are no leaks that I can find, the coolant doesn't seem to be coming out of the exhaust or the heater core. When it over heats it pushes the coolant into the overflow. Could it be a stuck thermostat?
Apr 6, 2017 at 4:30 PM (Merged)
STEVE W.
  • 15,113 POSTS
Martin - Have you been able to repair your vehicle or found the problem? Please post back as you may help others with your repair. Thank You.
Apr 7, 2017 at 10:14 PM
MACGYVER247
I had this problem with my car it was the head gasket it cost me $1,200.00 to have it fixed.
May 14, 2018 at 11:24 AM
