So this has been ongoing. First, about seven months ago, started blowing cool air on the passenger side. According to what I have read, this is a partial heater core blockage. Regardless, the car was running fine no problems. About five months ago it started heating up after getting off the highway. Needle would go past halfway but still not bad. Dealer recommended a coolant flush. Sadly that did not help. Testing shows it getting up to 225-230 Fahrenheit. Changed out the thermostat, no difference. Fans kick on so I do not think that is the issue. Not throwing any codes and not loosing coolant or oil. Only thing I can think of is the water pump or temperature sensor. Would a partially blocked heater core cause this? Any suggestions?
Feb 8, 2018 at 12:05 PM
