Overheating
2006 MAZDA 3
180,000 MILES • 2WD • AUTOMATIC
On Friday I was driving and noticed the A/C went out. A couple minutes later I realized the temperature gauge wasn't reading anything. so I drove a couple miles home with the heat on and after I parked, saw white smoke/steam from left side of hood. I waited a bit and opened my hood and really didn't see anything broken or leaking. I'm wondering if I add coolant will I know if that was the issue or what might be the problem?
Aug 22, 2021 at 2:05 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
This first thing I would suggest is to check the coolant level in both the radiator and overflow bottle. Use any brand of ethylene-glycol based coolant. You can buy a bottle of pre-mixed coolant as opposed to concentrate which you would have to dilute with water. When a car is running hot the are safety precautions like cut-off switches in the ac system to shut it off to not cause additional issues from engine overheating. After you check and possibly add coolant get back to us and we'll go from there.
Here is a tutorial on how cooling systems work:
https://www.2carpros.com/articles/engine-cooling-system
Hope this helps and thanks for using 2CarPros.
Aug 22, 2021 at 11:39 PM
