Overheating
2001 BUICK CENTURY
120,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
MATT GORGON
Replaced the thermostat and water pump and the car is still getting hot and overheating. no heat in car when the heater is turned on. what should i check?
Nov 12, 2017 at 12:48 PM
SQM
  • 6,383 POSTS
Do you know if your cooling fans are coming on? You can open the hood and check to see if they come on when the engine is running.
As for not getting heat, you might have a clogged heater core. You can try flushing the system, which can clear out the system.
And if it still does not fix the heater issue then the next step would be change out the heater core.
You might find this article helpful:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/coolant-leak-symptoms
Let me know of any questions.
Thank you.
Jul 17, 2021 at 11:14 PM
