After the vehicle sits overnight, check the coolant level. It is critical that the cooling system is bled (after repairs) to be sure to remove all of the air that is trapped in the system during the refill process.
This guide can help us fix it
https://www.2carpros.com/articles/engine-overheating-or-running-hot
One way to "bleed" the air from the system is to disconnect the small hose(s) that connects to the top of the coolant reservoir during the filling process be sure to raise the disconnected end of the hose above the level of the top of the reservoir. Air will move to the highest point in the system (the raised small hose)during the refill, thus escaping and eliminating air pockets which can cause an engine to overheat.
Nov 24, 2017 at 6:24 PM
