overheat, check for blown head gasket
2016 FORD EXPEDITION
20,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
PETE ALLPORT
This is a ford v8 in a boat actually.. the boat was taken out first time this year, and within ten minutes was at 230 temperature. was shut down, and found water was not getting from lake into engine cooling system.. want to know, when I remove spark plugs and crank engine do spark plugs need to be kept on ignition wires so the coils can keep firing built up energy? I have accidentally burned out motorcycle coil by not doing this. I know how to do rest of testing procedure. thanks
May 19, 2019 at 1:49 PM
SCGRANTURISMO
  • 4,897 POSTS
To do a compression test all the spark plugs should be out of the engine. The coils or plug wires are going to be off the spark plugs when they come out, so the coil(s) being able to discharge is of no concern. I have included a couple of links below for you to go to:
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 19, 2019 at 2:16 PM
