after replacing water pump, thermostat, flushed radiator it overheats at idle
2002 PONTIAC MONTANA
170,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
REDBONE
MEMBER
FOLLOW
Van has new water pump, thermostat, flushed radiator and it overheats at a idle. could the heater core be bad?
Jan 27, 2017 at 4:29 PM
CARADIODOC
CERTIFIED EXPERT
If the overheating does not occur at highway speed when natural air flow through the radiator is sufficient, the best suspect is an inoperative radiator fan.
