Hi Denvbroncos,
Unfortunately, this is not definitive. However, you have a very good sign of a head gasket issue with excess pressure in the cooling system.
Here is a guide that will take you through the best ways to determine a head gasket issue:
If you don't have some of these tools, you can rent them from the parts stores but I would start with a compression test. This will be the most definitive. You can then perform a cylinder leakage test but if you have low compression then you pretty much know that it is leaking into the coolant passages. A cylinder leakage test will tell you where you are losing your compression.
Let me know what you find and I will be happy to assist further if needed. Thanks
Jun 9, 2019 at 6:44 PM
