my reservoir tank wont drain back to rad replaced thermostat and radiator cap didn't help had vacuum test done was told it was head gasket but there is no signs of that no white smoke no signs of oil contamination when i went to remove reservoir to check it when i lifted it up to look at then the coolant drained into rad this seemed weird I'm not sure if it is head gasket but i would like your thoughts on this. Thank you.
Aug 27, 2022 at 7:47 AM
