overdrive light flashing?
2007 FORD EXPLORER
116,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
NIGHTRIDERPLYR
My overdrive is blinking?
Feb 13, 2019 at 11:55 AM
Good afternoon,
Does the transmission work correctly?
If it does the light in the handle could be the issue.
If it does not, it may be the wiring to it or a transmission issue.
Are there any codes stored?
Feb 13, 2019 at 1:25 PM
NIGHTRIDERPLYR
Thanks for the response, there are no codes showing. in the mornings when transmission is cold, it does not what to shift into overdrive, but after driving for about a mile and a half it shifts smoothly the rest of the day. Truck shifts smoothly other than that.
Feb 13, 2019 at 3:41 PM
Got it.
I would start by changing the oil/filter in the transmission. That may take care of the morning issue.
As far as the light, it sounds like you need the stalk replaced.
Feb 13, 2019 at 3:51 PM
MIKEYG79
The overdrive light started flashing the other day. Had them check at Jiffy Lube but they said it was a sealed trans and had to go to the dealer. They did give me the computer code which said it was some kind of pressure solenoid B. I assume that is in the transmission. I have an appointment at the dealer tomorrow to diagnose it.
The manual says that when this light flashes have the transmission serviced, which does not seem so bad but over the phone the service guy sure made it sound likely to be huge.
The service guy on the phone started telling me how much it is for a new transmission--$4000.This is making me uneasy. Does replacing the solenoid usually take care of it or is it more likely that the transmission need replacement for this car?
I don't have the $$ for a new one.
Can you give me any insight?
Thanks
Mike Guay
Dec 21, 2020 at 1:19 PM (Merged)
Yes the trouble code is what you should go after first. The solenoids go out all the time and are not that bad to change. You will need to jack the car up safely to do the repair. Here is a guide for that.
Then you will need to drop the pan.
Also check the connection at the transmission plug for corrosion. Here are some guides for the job. To refill the transmission you basically pump fluid in from the bottom and let the excess run out.
Please let us know what happens and upload pictures or videos of the problem.
DUNDEE628
just had the car put on the road after a minor accident. Had the right front hub bearings replaced and when my husband was driving to work the overdrive light started flashing and check transmission came up. We took it to a servicer and they said it pulled the gear ratio error in gear 5. is there anything that can be done as we do not have $2000 to have the transmission rebuilt
ED-WEEZY21
  • 248 POSTS
Unfortunately, no. Incorrect gear ratio codes and caused by internal failure and the transmission either needs to be replaced or overhauled. You can go to a junkyard and get a transmission but you always risk the chance of having that same problem. Most junkyards will give a warranty but they don't cover the labor. See if the mechanic can give you a better estimate or shop around for the best price but BE SURE to pick a reputable shop. Best of luck.
SAMKR
I have a 2003 Ford Explorer(V6) and as I was driving down the highway my Overdrive light starts flashing(I was not towing anything) what could this be.
I hate to say it, but you need to have the computer scanned to identify where the problem is coming from. If the light is flasing, chances are there is a sensor issue. The only way to be sure is to retrieve a trouble code from the computer to identify which one.
NOTE: Many parts stores will scan for free; however, most of them don't have a good enough scanner to check ABS, TRANS... codes. You will need to take it to a shop or a trans shop.
CAMILO CB
  • 10 POSTS
I noted that my auto trans has a delay on the shifts. I press on gas and does not respond according. The engine rpm increases and the gears delay to engage. So, i have to depress the pedal and then it engages. Also the OD light starts blinking. Sometimes, it works perfect. What should i do?
I was thinking of changing the trans fulid and filter.
Do you have the procedure to change the trans fluid? I would appreciate to have it has well.
Dec 21, 2020 at 1:31 PM (Merged)
Have you had the computer scanned?
CAMILO CB
  • 10 POSTS
Not, yet. The Service Engine Soon Light is on but i did not have a chance to retrieve the code as i had to leave home couple of days after that to work. I'll do that when i get home. Will be the first thing to do before touching anything. I hope is not serious.
Let me know what you find when you have the chance.
CAMILO CB
  • 10 POSTS
I will let you know when i get the codes.
Thanks.
Glad to help.
LINZLIBRA12000
i have an '02 exlorer and mine does the same thing i have no idea why though i will be watching your question hopefully WE can get and answer
Honestly, it could be several things causing a delayed shift. If the light is flashing, the computer needs scanned to determine where the problem is coming from.
CAMILO CB
  • 10 POSTS
[quote:30d2e9ac02="Jacobandnickolas"]Glad to help.[/quote:30d2e9ac02]
I've retrieved the code and it's: P0747 (Pressure Control Solenoid A).
Now i do have another problem: After been driving like that for couple of days after experiencing shift delays, the car won't go on reverse. I tried and it went with difficulties. I parked the car and quit driving it. Also re-scanned to see if there's a new code and just says the only code which is P0747.
Is it serious?
CAMILO CB
  • 10 POSTS
[quote:e6aac701ef="Jacobandnickolas"]Honestly, it could be several things causing a delayed shift. If the light is flashing, the computer needs scanned to determine where the problem is coming from.[/quote:e6aac701ef]
Ok. the code is P0747. My idea was to change the trans fluid 7 filter before that. Now i need help on what i have to do. Where is the Pressure Solnoid A located. Just replace this solenoid or it's better to replace all at once if they're in one block/pack.
CAMILO CB
  • 10 POSTS
[quote:872b1198e6="Jacobandnickolas"]Let me know what you find when you have the chance.[/quote:872b1198e6]
Is it serious?
CAMILO CB
  • 10 POSTS
Is it serious?
It is in the transmission. It is attached to the valve body.
LDIXON1205
Transmission problem
2001 Ford Explorer 6 cyl Automatic 161000 miles
when i put my truck in drive it moves like someone is pushing it by foot, but if i shift manually its ok and my overdrive light flashes
BLUELIGHTNIN6
  • 16,542 POSTS
When the O/D light flashes (means you have no O/D) that is usually becuase of a faulty sensor on the tranny. No O/D is protective mode (limp mode) that the tranny uses when a fault has been detected by the vehicle's computer. You will need a diagnostic done on the tranny to pinpoint the exact culprit here.
Thanks for using 2CarPros.com!
CAMILO CB
  • 10 POSTS
So, i have to order the new Solenoid Block and replace it.
What about the issue of No Reverse?
CAMILO CB
  • 10 POSTS
[quote:eaa51e9551="Jacobandnickolas"]It is in the transmission. It is attached to the valve body.[/quote:eaa51e9551]
I need to order a new solenoid pack/block.
What about the No Reverse problem? Is it linked to the P0747 Code? Hope so.
The pressure control solenoid is stuck on, so that could play a role with the reverse. I can't guarantee it will fix it, but I feel that it may be the problem.
PPKAO6
My overdrive light starts flashing after a few miles of driving. I push the overdrive light button an I can feel it kick off and the rpm go up, push the button to turn it on I can feel it turn on an rpm drop. What could be the problem?
MHPAUTOS
  • 31,937 POSTS
is the light flashing a code? a flashing light is normally a fault code. look for a sequence in the flash. if its just a continuous flash get a transmission code read done.
WRENCHTECH
  • 20,761 POSTS
The flashing light is an indicator that there are codes stored in the TCM that need to be recovered. You would need a professional scan tool capable of accessing the Transmission Control Module. A generic code reader will not be sufficient for that.
RAWARD2
What can cause the overdrive off light to blink on and off after the car has been driven 10 to 20 miles?
ALANR66
usually when the od light starts blinking the transmission is on the way out
TAKYFORD
i was told to just unplugg the battery for a few hours to let the pc to reset.. i have a 95 and it worked.
DEBORAHBRYAN
  • 6 POSTS
my overdrive light comes on and blinks off and on when i sometiimes round a curve or when i am speeding up. I have to turn the engine off then back on to stop it from blinking. Transmission does not shift right when it is doing this. What could cause this or is my transmission bad or is it a sensor
First, if it happens when turning, make sure the fluid is clean and full. As far as your question, what does the trans do when the light is flashing? Also, when it is doing this, you need to have the computer scanned to identify what is causing the problem.
Let me know what happens when it lights.
DEBORAHBRYAN
  • 6 POSTS
changed transmission fluid recently when the light comes on and flashes the trans does not want to shift correctly it kind of jumps into next gear but when it doesnt come on my trans shifts just fine
Dec 21, 2020 at 1:32 PM (Merged)
If I had to guess, I would say you have a bad shift solenoid which is causing the problem. My best recommendation is to have the computer scanned when the light is flashing. That way you will know exactly where the problem is coming from rather than a guess from me. I don't like to give information without being sure.
Try that and let me know what you find.
DEBORAHBRYAN
  • 6 POSTS
thank you i will
Let me know what you find.
