Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-350
Drivetrain
Transmission
Symptoms
Slip
Overdrive flashes on and off?
1995 FORD F-350
289,000 MILES • AUTOMATIC
STEPHSTEPH
MEMBER
1 POST
FOLLOW
Overdrive flashes off. Transmission is slipping.
Jul 31, 2023 at 2:44 AM
CERTIFIED EXPERT
It sounds like it needs to be rebuilt. I would check the fluid level first and maybe service the transmission to see if that helps.
Here are a few guides to help us fix the problem:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
and
Also, we should run the codes because you might have a pressure regulating solenoid that is not working.
Check out the images (below). Please let us know how it goes
Jul 31, 2023 at 4:30 PM
