The first thing I need you to do is check transmission fluid level and condition.
Follow these directions for level testing.
Start engine and allow to idle for at least one minute. Then, with parking and service brakes applied, move selector lever momentarily to each position, ending in the park or neutral position.
see pic 1
7. Check the transaxle fluid level and add an appropriate amount to bring the transaxle fluid level to 3mm (1/8 inch) below the lowest mark on the dipstick (Fig. 213).
8. Recheck the fluid level after the transaxle has reached normal operating temperature (180°F.). Refer to Fluid Level and Condition Check for the proper fluid fill procedure.
9. To prevent dirt from entering transaxle, make certain that dipstick is fully seated into the dipstick opening.
__________________
When checking, make sure the fluid is a reddish pink color and doesn't have a burnt smell.
__________________
Do this first and let me know what you find. Also, let me know if there are any service lights staying on when the engine is running.
Dec 8, 2020 at 5:44 PM
