Hi Mr. Ocha,
I just want to confirm the light is staying on consistently and not flashing. If it is flashing then you need to pull codes and repair as soon as possible because it could cause damage.
If it is steady then it could just be a shifter issue. I would still suggest pulling codes and seeing if you have a circuit issue. It could be the button itself being shorted, wiring, or even a PCM issue however, I would suspect a button issue. A lot of times these just get contaminated with dirt, grime, drinks spilled on them and other stuff.
Hopefully you have a code and that will get us to a resolution quickly. Let me know what you find and we can go from there. Thanks
Jul 11, 2019 at 6:40 PM
