Overheats when idle AC on
2013 MITSUBISHI PAJERO
110,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
FARHAN UL HAQ
When it is too hot, on idle AC on starts heating up, if switch off the AC, the heat needle goes back to normal position.
Jul 2, 2018 at 1:12 AM
With the engine running and the AC on can you hear the radiator cooling fans running?
Please let me know, Cheers, Ken
Jul 3, 2018 at 1:17 PM
FARHAN UL HAQ
Yes fans are working fine. Just have a doubt that is there any possibility of A C compressor load is creating the problem? Because when AC switched off the needles comes back. When the car heats up, the AC stops blowing cold air.
Jul 8, 2018 at 3:36 AM
The compressor will not cause the engine to heat up. Can you see if there is an obstruction in front of the radiator like a plastic bag? Also, it sounds like the engine could be close to overheating. Here is guide that will help you troubleshoot the problem:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Jul 13, 2018 at 4:45 PM
