When it is too hot, on idle AC on starts heating up, if switch off the AC, the heat needle goes back to normal position.
Jul 2, 2018 at 1:12 AM
CERTIFIED EXPERT
With the engine running and the AC on can you hear the radiator cooling fans running?
Please let me know, Cheers, Ken
Jul 3, 2018 at 1:17 PM
FARHAN UL HAQ
MEMBER
Yes fans are working fine. Just have a doubt that is there any possibility of A C compressor load is creating the problem? Because when AC switched off the needles comes back. When the car heats up, the AC stops blowing cold air.
Jul 8, 2018 at 3:36 AM
CERTIFIED EXPERT
The compressor will not cause the engine to heat up. Can you see if there is an obstruction in front of the radiator like a plastic bag? Also, it sounds like the engine could be close to overheating. Here is guide that will help you troubleshoot the problem:
