over heating and blowing cold air
1999 ACURA TL
83,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
MAUIIMO
replaced radiator, heater core, main fan, sensors on left side of motor cant find the one on the right that sends the signal 4 main fan... car is still over heating also changed thermostats 3 times seems like if thermo is not opening car is over heating and blowing cold air inside
Feb 17, 2015 at 5:43 PM
Have you tried checking if there is an air block in the system? Also, which fan isn't working? Does the car overheat if you are driving at highway speeds? Are you sure the water pump is good? Do any of the heater or radiator hoses get hot?
Feb 17, 2015 at 6:37 PM
CJ MEDEVAC
  • 11,004 POSTS
DIFFERENT FELLER
GOTCHA A FEW PICS OF SOME WATER PUMPS W/ PLASTIC IMPELLERS
THE MEDIC
Feb 17, 2015 at 7:57 PM
MAUIIMO
I will try water pump tomorrow hopefully it's not difficult to do...never thought the water would be the problem. ....radiator hoses do get hot and hard....even without a thermostat. ....I also ordered the transistor assy...see if that helps for my cold air blowing out... Why do I have to select off on screen to turn heater on?.....selections for vent or foot or defrost alway start on a/c if I do think select off on screen it will blow out cold air even if temp is set at 90 degrees
Feb 17, 2015 at 8:43 PM
CJ MEDEVAC
  • 11,004 POSTS
GOOD NEWS?
THE MEDIC
Feb 22, 2015 at 9:11 AM
