Okay, if you heard the fan, then there is a better chance it is the water pump. I just do not want you to get taken.
Arizona. You have no idea how much I have always wanted to see the state. I am near Pittsburgh. Tonight, it is 23 degrees, snowing and blowing. Ugh! If heaters do not work here, we are in trouble. LOL I have always wanted to come there to find an old muscle car. Maybe someday. Until then, I will watch everything nice rust away here.
Anyway, I would like you to ask the tech one more thing. Take a look at this. It is basically the same as what you are dealing with. And the water pump was replaced, but the vehicle still overheated. They found a kinked hose was the problem. Read through this and consider asking the tech if the lower radiator hose gets hot and if he could check the specific hose mentioned. I attached a picture which shows hose number 2.
Replaced Thermostat and Water Pump Already, No Change.
When Run with Out Thermostat, Vehicle Does Not Overheat, and Engine Temperature Does Not Exceed 140 Degrees.
Cooling Fans cycle as Specified.
With thermostat installed the lower hose never gets hot.
Overheating
We found heater output was insufficient.
We flushed out the heater core and heater output improved, but not very much.
TECH-ASSIST
02/09/2017 | 09:56:37
1 Repair(s) Available
Verified Repairs(2)
TECH-ASSIST
02/09/2017 | 10:19:06
After multiple vacuum drain and fills, condition remains the same, doesn't seem to have an air pocket.
Vehicle doesn't boil over, just runs hot and warning light will flash. Fans come on.
We looked at the flow diagram found the #2 hose in the diagram hits squarely at the back of the Thermostat, because of the way of the outlet line back to Thermostat housing, it caused the overheat condition along with poor heater operation.
Replaced the Heater Core, over heat issue solved.
______________________________
Take care of yourself. Feel free to let me know if you have any other questions. Also, I wish you and your family a nice holiday season.
Nov 27, 2018 at 8:48 PM
