I have an overheating problem. i have changed the water pump gaskets and reservoir cap and thermostat.
Sep 26, 2020 at 2:50 PM
CERTIFIED EXPERT
If the thermostat is new then we can assume that it is not the issue for now. The next thing to check is for restrictions and if the fans are turning on. When the engine is starting to get hot the fan should be on high so let's double check this and go from there.
If there is a place that is hotter then the rest of the engine/cooling system them we may have a restriction there.
Let me know about this info and we can go from there. Thanks
Sep 26, 2020 at 3:31 PM
RACHAEL SWITZER-HUBENAK
MEMBER
Fans do work.
Sep 27, 2020 at 4:27 AM
CERTIFIED EXPERT
Okay. That is good. So we need to check around the engine for restrictions including the radiator. It should progressively get cooler as you work your way down the radiator. If it is hot and then drops quickly then we may have a restriction there.
Sep 27, 2020 at 10:37 AM
MEMBER
Nope, that's good. no problem with the radiator.
Sep 27, 2020 at 11:48 AM
CERTIFIED EXPERT
Okay. How did you prove out the radiator is okay?
When does this overheat? Idling or do you have to drive?
Also, we need to check around the rest of the engine and cooling system for hot spots. Thanks
Sep 27, 2020 at 5:04 PM
MEMBER
It gets hot while driving. what are the other hot spots?
Sep 28, 2020 at 7:24 AM
CERTIFIED EXPERT
You have to check around the engine with a laser temperature meter for the hot spots. There are no sure bets on that.
As for overheating when driving, that is most likely due to poor air flow like a plugged radiator not allowing air flow through it or a restriction within the cooling system. Like a collapsed hose or restriction inside the passages.
Sep 28, 2020 at 6:27 PM
MEMBER
How do you check for a collapsed hose?
Sep 29, 2020 at 7:02 AM
CERTIFIED EXPERT
The easiest way is to inspect them. If they are literally collapsed or sucked in then that is the easiest way. If they are not, you want to squeeze them as the engine is running and they should feel firm but you should be able to squeeze them and they "bounce" back. Basically if they are soft and don't feel like they returning to their normal size then they are collapsed.
