Hi again. I am here to help if you want to give it a try. As far as the pictures, it does not look like oil has contaminated the system. Either that is corrosion from age or someone put a stop leak in the system at some point.
I would recommend flushing the system (engine) and replacing both the radiator and thermostat. If any of the hoses are bad or look cracked or swollen, replace them at this time.
Here are directions for replacing the thermostat and radiator for your vehicle. As far as flushing the block, any parts store will sell cooling system flush products. Just follow the directions on the product.
______________________________________________
CONVERSION CALCULATOR
2002 Toyota Camry SE Sedan L4-2.4L (2AZ-FE)
Vehicle » Engine, Cooling and Exhaust » Cooling System » Radiator » Service and Repair
SERVICE AND REPAIR
Removal & Installation and Disassembly & Reassembly
DRAIN COOLANT
DISCONNECT RADIATOR HOSE INLET
DISCONNECT RADIATOR HOSE OUTLET
DISCONNECT OIL COOLER INLET HOSE (A/T TRANSAXLE)
DISCONNECT OIL COOLER OUTLET HOSE (A/T TRANSAXLE)
REMOVE AIR CLEANER INLET ASSEMBLY
Remove the 2 bolts and the air cleaner inlet.
REMOVE RADIATOR SUPPORT UPPER
Disconnect the 2 horn connector.
Remove the hood lock release lever cover.
Remove the bolt shown in the illustration.
Remove the 4 bolts and radiator support upper.
REMOVE RADIATOR ASSEMBLY
Disconnect the fan motor connector.
Remove the radiator w/ fan.
REMOVE RADIATOR SUPPORT CUSHION
REMOVE RADIATOR SUPPORT LOWER
REMOVE FAN ASSEMBLY, W/ MOTOR
INSTALL FAN ASSEMBLY, W/ MOTOR
Install the fan assembly w/ motor to the radiator. Torque: 5.0 Nm (51 kgf-cm, 44 inch lbs.)
INSTALL RADIATOR SUPPORT UPPER
Install the radiator support upper with the 4 bolts. Torque: 14 Nm (142 kgf-cm, 10 ft. lbs.)
ADJUST HOOD SUB-ASSEMBLY
ADD COOLANT
CHECK ENGINE COOLANT LEAK
________________________________________________________
For thermostat replacement, here are the directions. Keep in mind, the thermostat needs removed to properly flush the engine block. The last two pictures correlate with thermostat replacement.
Vehicle » Engine, Cooling and Exhaust » Cooling System » Thermostat » Service and Repair
SERVICE AND REPAIR
REPLACEMENT
DRAIN COOLANT
REMOVE WATER INLET
Remove 2 nuts, and disconnect the water inlet from the cylinder block.
REMOVE THERMOSTAT
INSTALL THERMOSTAT
Install a new gasket to the thermostat.
Install the thermostat with the jiggle valve upward.
HINT: The jiggle valve may be set within 10° on either side of the prescribed position.
INSTALL WATER INLET
Install the water inlet with 2 nuts. Torque: 9 Nm (92 kgf-cm, 80 inch lbs.)
ADD COOLANT
INSPECT CHECK ENGINE COOLANT LEAK
A thermostat is very inexpensive, so I recommend just replacing it. Also, I am suggesting these repairs based on the idea that the engine still starts and runs. If you worry about engine damage, please refer to my original post. Also, if you start the engine to see if it runs, do not run it longer than a few seconds since there is no coolant in it.
Let me know if you need help or more information.
Jan 25, 2021 at 10:35 AM
(Merged)
