Outside o ring distributor leak
1997 NISSAN ALTIMA
175,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
OHYEA
  • 153 POSTS
What are the steps to replacing the outside o ring to the distributor? I had read a forum that you have to set engine to TDC 0 or something, is this true? Thank you.
Dec 26, 2015 at 10:49 AM
remove the distributor cap and move out of the way.
I would use a paint stick to mark where the base goes in relation to the block.
also, mark the rotor to the distributor as a reference.
if you mark these 2 places, you can be assured to install the distributor in the exact position you removed it
Dec 26, 2015 at 11:26 AM
