I got a leak at my rear seal y'all got any instructions/videos on how to replace it?
May 9, 2021 at 10:28 PM
CERTIFIED EXPERT
Can you please tell us which seal engine, transmission or differential?
May 11, 2021 at 9:59 AM
JDUB2009
MEMBER
It's a 1995 Chevrolet Cheyenne 1500 2wd 4 speed manual with overdrive with the 5.0L 305. And it's the output shaft seal on the transmission.
May 11, 2021 at 7:13 PM
CERTIFIED EXPERT
you will need to remove the driveshaft. this guide will walk you through the steps with the seal location in the diagrams below. Use a chisel to remove the old seal then install the new seal using a flat steel or seal installer.
