Outer tie rod castle nut torque
1998 CHRYSLER CONCORDE
160,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
OREO101
  • 103 POSTS
Hi, can you please tell me the torque ft lbs for castle nut on outer tie rod? Thanks!
Mar 11, 2021 at 2:35 PM
CARADIODOC
  • 34,306 POSTS
27 foot pounds. Here's what I found for your vehicle. I'm not sure what to make of the last two. The knuckle is typically another name for the spindle which has the steering arm cast as part of it on most vehicles. On yours, the steering arm is part of the strut, not the knuckle.
Adjusting Sleeve Pinch Bolt .................... 34 Nm (25 ft. lbs.)
To Strut Steering Arm Nut .................... 37 Nm (27 ft. lbs.)
Tie Rod End To Knuckle .................... 61 Nm (45 ft. lbs.)
Mar 11, 2021 at 2:57 PM
OREO101
  • 103 POSTS
Thanks! This helps.
Mar 15, 2021 at 9:38 AM
