Welcome to 2CarPros.
This vehicle has an expansion valve. It is located on the firewall under the hood. Here are the directions for replacement. The attached pictures correlate with the directions.
________________________
2012 Volkswagen Beetle (5C1) L5-2.5L (CBTA)
Expansion Valve, Removing and Installing
Vehicle Heating and Air Conditioning Expansion Valve Service and Repair Removal and Replacement Expansion Valve, Removing and Installing
EXPANSION VALVE, REMOVING AND INSTALLING
Special tools, testers and auxiliary items required
Torque Wrench 1331 5-50Nm (VAG1331)
A/C Service Station (VAS6007A) (or succeeding model)
Engine Bung Set (VAS6122)
ATTENTION!
Danger due to refrigerant coming out under pressure.
Danger of frost bite to skin and other parts of the body.
Extract the refrigerant and immediately open the refrigerant circuit after that.
If the refrigerant was extracted more than 10 minutes in the past and the refrigerant circuit was not opened, extract the refrigerant again. Pressure in the refrigerant circuit is caused by evaporation.
The expansion valve atomizes the streaming refrigerant and controls the flow rate so that the vapor is gaseous only at the evaporator outlet, depending on the heat transmission.
Refrigerant must be extracted beforehand using the A/C Service Station (VAS6007A) or succeeding model.
Environmentally hazardous draining of refrigerant is an offense punishable by law.
See notes.
Note the safety precautions in vehicles with a start-stop system. Refer to [Vehicles with Start/Stop System General Information ] See: Heating and Air Conditioning > Components > Vehicles with Start/Stop System General Information.
Depending on engine and vehicle version, it may be necessary to loosen or to remove the following components (upper engine cover, compressed air pipe to throttle valve part and, depending on engine, the intake manifold, etc.).
Removing
Perform the Following Work
- Extract the refrigerant with the A/C Service Station (VAS6007A) (or succeeding model) from the refrigerant circuit.
The heat shield is installed in front of the expansion valve, depending on engine.
Loosen, but do not remove, the heat shield and pull it off slightly. The coolant system does not need to be opened.
If Equipped, Loosen the Heat Shield
- Remove nut - 1 - (10 Nm).
- Remove the lock washer - 2 - and the clip - 3 -.
- Loosen the heat shield for the expansion valve - 4 - from the bulkhead.
pic 1
- Remove the bolts - 1 - from the refrigerant line - 2 - (10 Nm).
- Carefully remove the refrigerant lines - 2 - from the expansion valve - 4 -.
- Remove the bolts - 8 - from the expansion valve - 4 - to (5 Nm).
- Carefully remove the expansion valve - 4 - from the heater and A/C unit.
pic 2
Installing
Install the expansion valve in reverse order. Note the following when doing this:
Always replace the O-ring for the high pressure refrigerant line - 3 and 5 -.
Always replace the O-ring for the low pressure refrigerant line - 6 and 7 -.
Lubricate O-ring seal lightly with refrigerant oil before installing.
Jul 19, 2019 at 7:29 PM
