I have some good news. Luckily for us, there are some great free resources out on the interwebs about how to perform the software update yourself along with the firmware file itself. There are even some modified versions that add extra functionality to your navigation. And yes, it will reset your extra languages to their original form. In my example, from Russian back to English. There may even be versions for your specific language if you look around the web.
I went ahead and installed the latest version (v32) that is modified to have a night mode and an ///M-badge splash screen.
I have provided links to the necessary downloads as well as links to handy guides to help you get started with the process.
Keep in mind that you do need a CD/DVD burner in order to create the update disk. If you do not have one, call up a friend or buy one off Amazon for some 30 bucks. I used the friend option :>
Be careful to follow the guides step by step if you are unsure what you are doing as there is a difference in the navigation system's models.
Version 32 is the latest software for BMW MKIII and MKIV navigation computers, released in 2008. On your current system, head to the 'Settings' option on the home screen, and take a look at the top right. It'll say S/W (software) x-1/aa where 'x' is your computer model, 1, 2, 3, or 4, and 'aa' is your revision number. /00 is version 32.
All together I spent 69 cents as opposed to 125 EUR asked by the dealer.
Links to downloads:
-v32 Software Update (1):
http://www.neiloakley.com/
-v32 Software Update (2):
https://e39source.com/downloads
-ImgBurn:
http://www.imgburn.com/index.php?act=download
How to create a software update CD/DVD:
https://www.youtube.com/watch?v=fQS7MTYp6dY
How to install the software update onto your MKIV system (the car model in the video may be different but it doesn't matter as long as the navigation system is the same model - MKIV):
https://www.youtube.com/watch?v=B7sFrpnXFCs
Use IMGBurn to burn the .cue file to a CD. Use the slowest burn speed possible, and do verify the burn at the end. Simply follow the video instructions if you are unsure.
Hope this helps anyone else looking to save some money!
Jul 4, 2019 at 12:11 AM
