Code is C1244, open or short circuit in deceleration sensor circuit?
2005 TOYOTA COROLLA
123,456 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SUP BOY
Code is C1244, I have bn trying to locate the sensor on the vehicle, the ABS and brake lights are on the instrument cluster.
Sep 25, 2024 at 11:43 PM
The C1244 code on a 2005 Toyota Corolla indicates a problem with the Yaw Rate Sensor. This sensor is on the left side of the center console. I would check the electrical connector for corrosion because it can get wet and stop working. Clear the codes once the repair is complete. Check out the images (below). Please let us know what happens.
Sep 26, 2024 at 3:00 PM
SUP BOY
Can’t still find the sensor at that location?
Sep 27, 2024 at 1:46 PM
Did you click on the images in the post above? It shows where the location to the Yaw sensor is.
Sep 27, 2024 at 1:47 PM
SUP BOY
I have checked where you as me to check but didn’t find anything there
Sep 28, 2024 at 6:14 PM
It is under the driver's seat, it might be under the carpet.
Sep 29, 2024 at 9:55 AM
LEKMAN32
c1244 open or short circuit in deceleration sensor locations please.
Toyota Corolla 2009
Apr 7, 2025 at 6:22 PM
