last cylinder flooded with gas on rear drivers side ,compression good ,new cylinder heads installed,plugs,wires , while running strong smell of gas from exhaust pipe i tested with anold light on injector wire flashes. so listen for ticking while running no ticking all other injectors working fine just the one . i hooked up a outside injecter started engine seems like injector is sticking open and gets hot fast . no ticking sound ececpt when first turn on engine just one click and then gets hot like full power to injector
Mar 24, 2016 at 6:08 PM
