Engine Mechanical problem
1996 Opel Kadett 4 cyl Front Wheel Drive Manual
I have done the motor on this vehicle and now experince problems in getting this motor to run. I have been through the basics, checked for spark on all 4 cylinders with a timing light, checked ecu signals, checked ecu and jettronic wiring. I suspect air, but where do I start? The pipes appear to be good. Will the car start without the breather pipe from the sump to inlet side of throttle via the cam box?
Apr 28, 2009 at 9:11 AM
