Computer problem
1996 Opel Kadett 6 cyl Front Wheel Drive Manual
Hi
The car is a 1996 Opel Kadett 200iS with a 3.2 v6 engine conversion. I was running a Omega B 2.5 V6 ECU but was using a Vectra B intake . I got hold of a complete Vectra ECU and loom and installed it.When Cruising at higway speeds the EML comes on as soon as you lift off the throttle. Codes recorded are P0130 and P1050. The old ecu a Motronic 2.8.1 did not give any errors. On the live dada file I saved the mv output of the sensors drop to 0. The car does not suffer from any drivability problems. Could a leak on the intake cause this or are the sensors not compatable with the Vectra ECU ?
Thank You
Hi
Thank You
Jul 5, 2010 at 5:58 AM
