Opel corsa C hatchback clutch problems
2006 OPEL CORSA
160,000 MILES • 1.4L • TURBO • FWD • MANUAL
MOEKETSIV
Hi there,
I have a problem with my clutch, it just went loose for some reason, I was advised it could be the Clutch master cylinder, however I also found a leak of brake fluid on the pipe going into the clutch master cylinder where the clutch is bled. The clutch pedal comes back up but there is no pressure, it is just loose so I cannot change into the gears.
Dec 8, 2014 at 9:56 PM
MHPAUTOS
  • 31,937 POSTS
It sounds like the line or internal seal has failed which can happen. I would replace the unit (all in one) and that should fix the problem.
Here is a guide that can help as well.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Some clutches have a pedal return spring, but if you have little or no pressure and signs of fluid leak, I would be looking at the master cyl, if it is wet where the push rod goes in, it will be leaking and need replacing.
Cheers
Dec 9, 2014 at 12:29 AM
MOEKETSIV
yes that is actually my situation, thanks for the feedback.
Furthermore I also had an issue with my fuel rail, it had a leak so I had to replace it however I have not tested if it is working, so I need advise on replacing the fuel rail does it also require that there is no air in it if so how do i bleed it or remove the air.
Dec 9, 2014 at 1:55 AM
MHPAUTOS
  • 31,937 POSTS
Basically if it is petrol it will self bleed, if diesel you will have to bleed system, normally if the filter is full, just crack injector lines and crank until you see fuel pulsing out.
Dec 9, 2014 at 2:42 AM
MOEKETSIV
Okay Thanks
Dec 9, 2014 at 2:47 AM
MHPAUTOS
  • 31,937 POSTS
I hope all goes well, re post if you are still having problems.
Dec 10, 2014 at 12:05 PM
TOFFARE
Hi I have the same problem leaking as well and pedal loose but return spring bring its back up please can you give me assistance.
Sep 25, 2015 at 1:24 AM
MHPAUTOS
  • 31,937 POSTS
Check for where the leak is, master or slave cylinder, replace what is faulty, re bleed the system.
Sep 25, 2015 at 2:13 AM
