2007 Opel Corsa power loss & jerking with intermitted m
2007 OPEL CORSA
RICHWOOD
Engine Mechanical problem
2007 Opel Corsa 4 cyl Manual
Bought my daughter a opel corsa light 1.4I 3 month ago. The following work has been done on the car
Two new tyres and front brake pads. balancing and alignment and caster/camber replaced.
New plugs oil filter and oil changed, fuel filter and airfilter.
All of the above has not solved the problem of loss of power going hand in hand with jerking when going up a hill (even a slight incline) and there is an intermitted metal against metal sound coming from under the bonnet.
Any advice.
Nov 6, 2009 at 7:27 AM
DAVE H
  • 13,384 POSTS
check fuel pressure is good .. replace the coils and check/replace/clean the CKP (crankshaft position) sensor
Nov 8, 2009 at 4:45 AM
LETSHOLO
Don't have an answer to your problem. My car behaves the same way, did you manage to get a soulution for it? May you please share the solution with me. Replaced petrol pump, both oil and petrol filters, spark plugs and coil... Please help. My email address is as follows: [email protected]
Feb 16, 2010 at 2:16 PM
