2001 Opel Astra Thermostat?
2001 OPEL ASTRA
DMENCHER
2001 Opel Astra 4 cyl Front Wheel Drive Automatic 90K km miles
I have been experiencing a confusing problem recently with my otherwise very good used Opel.
For about 2-3 months, the car has run cold on downhills (down lower than 80 degrees) or fast straighaways, at which point the engine will run very rough, and then eventually stall when RPM dropped while slowing for a light or turn. This will not happen in traffic.
Just yesterday, though, on a long drive, I repeatedly turned on and off the AC, and miraculously, the car stopped running cold, and performed jsut as it should for the rest of the drive (even without the AC on for most of the drive).?
Thanks,
David, Jerusalem
Is this a thermostat problem? MAF? Idle setting?
May 18, 2008 at 12:33 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would start with fitting a new thermostat.
Mark (mhpautos)
May 18, 2008 at 5:01 AM
DMENCHER
[quote:233391d960="mhpautos"]Hi there,
Mark (mhpautos)[/quote:233391d960]
Thanks Mark.
Having ascertained that the thermostat is OK, could the poor performance and stalling at higher speeds be related to soot and dirt buildup due to clogged EGR vacuum hose? I have seen alot of comments about Opel EGR problems.
Thanks again,
David
May 21, 2008 at 4:35 AM
