Only have reverse and first
1996 CHRYSLER LHS
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MIKE STEW2
Hello. I recently began having problems with my car not shifting out of first gear. The check engine light comes on, as soon as it is put in reverse and then goes into gear with a “clunk”. I replaced the input and output transmission speed sensors, hooked up the OBD and cleared the check engine light. Then I took it for a drive. It shifted into R great, then smooth into first. Ran it down the highway, it shifted through the gears great. Drove about fifteen miles, then parked. About six hours later, I hopped in and instantly the check engine came on and it was back to not shifting. Any ideas?
Aug 15, 2018 at 12:55 AM
Yes, this usually happens when the transmission computer is going out. Here is the location so you can get a used one and plug it in. Also remote the electrical connectors and check for corrosion.
Aug 16, 2018 at 7:21 PM
